TRTC Web SDKAPI ReferenceEventsError CodesTypesTutorialsChangelog
中
Tutorial: Enable Audio Mixer
Enable Audio Mixer
Function Description
This article will introduce how to add background music during a call. Experience demo.
Run Demo
▶ Click to Run Demo
TRTC version 5.1+
The following platforms support adding background music during a call:
Operating System Browser Type Minimum Browser Version
Mac OS Desktop Chrome 56+
Mac OS Desktop Safari 11+
Mac OS Desktop Firefox 56+
Mac OS Desktop Edge 80+
Windows Desktop Chrome 56+
Windows Desktop QQ Browser 10.4+
Windows Desktop Firefox 56+
Windows Desktop Edge 80+
iOS Mobile Safari 14+
iOS WeChat Embedded Web ✖
Android Mobile Chrome 81+
Android WeChat Embedded Web ✔
Android Mobile QQ Browser ✖
Implementation Process
Start Background Music
Notice:
  • When playing online sound effect files, the sound effect files must support CORS and the access protocol must be https.
  • Supported formats include MP3, AAC (and other audio formats supported by browsers).
  • Before any user interaction, browsers prohibit web pages from playing media with sound. It is recommended to guide users to perform a click action before calling this interface.
  • Reference: Autoplay_guide.
await trtc.startPlugin('AudioMixer', {
  url: '../assets/count.mp3',
  loop: true,
  volume: 0.2
Update Background Music
Perform operations on the background music.
// disable loop playback
await trtc.updatePlugin('AudioMixer', {
  loop: false
// volume setting
  volume: 1
// pause music `count`
  loop: true,
  volume: 0.2,
  operation: 'pause'
// resume music `count`
  operation: 'resume'
// play `count` from 5s
  seekFrom: 5
Stop Background Music
Stop a background music that is not needed.
await trtc.stopPlugin('AudioMixer', {
API
trtc.startPlugin('AudioMixer', options)
Start background music.
options
Name Type Attributes Description
id string Set a unique ID for each incoming music URL
url string Music file URL. One of url and track must be passed in. If both are passed in, the url will be selected first.
track MediaStreamAudioTrack Since v5.4.3+, one of url and track must be passed in. can pass in a track extracted from the <audio/> tag. If both are passed in, the url will be selected first.
loop boolean <optional> Whether to loop play, default is false
volume number <optional> Set the initial volume, default is 1 (0-1). Not support iOS.
playbackRate number <optional> Set the playback rate, the default is 1.0
onDurationChange function <optional> Callback function, which will be executed after the music is loaded. The parameter is (duration: number) which indicates the total duration of the music
onTimeUpdate function <optional> Callback function, which will be executed after the music is loaded. The parameter is (duration: number) which indicates the total duration of the music
onEnded function <optional> Callback function, executed when the music ends (note that it will not be executed every time the music ends during loop), no parameters
  loop: true,
  volume: 0.2
trtc.updatePlugin('AudioMixer', options)
Update background music.
options
id string The unique ID for each incoming music URL you set when call startPlugin
seekFrom number <optional> Start seeking playback from which second, this parameter requires the music resource file to support HTTP range requests.
operation number <optional> Operation on the background music: 'pause' | 'resume' | 'stop'
Example:
  loop: true,
  volume: 0.2,
  operation: 'pause'
trtc.stopPlugin('AudioMixer', options)
options
Example:
Frequently Asked Questions
1. Cross-Origin Error
For example: Access to audio at XXX from origin XXX has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
Solution: You need to configure the CORS protocol for your online music files.
2. Incorrect Audio Format, Unable to Play in Browser
For example: NotSupportedError: The operation is not supported.
Solution: You need to use an audio format supported by the browser.
