TRTC Web SDKAPI ReferenceEventsError CodesTypesTutorialsChangelog
Tutorial: Enable Watermark Plugin
Function Description
This article introduces how to use the watermark plugin to add image watermarks on camera streams.
  • TRTC Web SDK version >= 5.3.0.
Implementation Steps
Install Watermark Plugin
import { Watermark } from 'trtc-sdk-v5/plugins/video-effect/watermark';
let trtc = TRTC.create({ plugins: [Watermark] });
Open Camera
await trtc.startLocalVideo({
  view: 'local-video'
  option: {
    mirror: false
Start Watermark Plugin
await trtc.startPlugin('Watermark', {
  imageUrl: 'https://web.sdk.qcloud.com/trtc/webrtc/test/qer-test/watermark/trtc-watermark-test.png'
After testing, you can replace the test image URL with your own watermark image. It is recommended to use a transparent PNG format.
Stop Watermark Plugin
await trtc.stopPlugin('Watermark');
API Description
trtc.startPlugin('Watermark', options)
Start watermark plugin.
options
Name Type Attributes Description
imageUrl string Required Image watermark URL
x string Optional Watermark left margin
y string Optional Watermark top margin
size string | number | object Optional When passing a string:
- "cover" scales the background image to fully cover the background area, which may cause parts of the background image to be invisible.
- "contain" scales the background image to fit entirely within the background area, possibly leaving some areas blank.
When passing a number:
- x scales the background image by x times, e.g., 0.5, with a valid range of (0,1]
When passing an object:
- You can specify manually by passing {width: 200, height: 300}
The default is cover
Example:
  imageUrl: 'https://web.sdk.qcloud.com/trtc/webrtc/test/qer-test/watermark/tv2.png',
  x: 0,
  y: 0,
  x: 0,
  y: 0,
    width: 100,
    height: 200
trtc.updatePlugin('Watermark', options)
Update the watermark image, position, and size.
options
await trtc.updatePlugin('Watermark', {
  x: 100,
  y: 200,
    width: 50,
    height: 50
Stop watermark plugin.
Example:
Q&A
1. Is the watermark mirrored?
The local preview image is enabled by default, so the watermark will also be mirrored. You can disable the local preview mirror image.
await trtc.updateLocalVideo({
  option: {
    mirror: false
2. Why does the screen flashes black briefly after updating the watermark?
Update SDK to v5.8.6+.
